For any porous material, one should avoid using citric bio enzymes. Satopradhan floor cleaner does not contain a citric enzyme, but for use on marbles or Italian marbles, we suggest you use it in very low quantities, i.e., add 20 ml floor cleaner to 5L of water. Still, to be safe, we recommend you do a patch test with your tiles by applying on a small portion, as some blocks are dense and sound.
