How do we store cocopeat after water is added to it?
The recommended approach is to use double the amount of water compared to the cocopeat being used at one time. If you have the convenience of storing 4-5 kgs of expanded cocopeat in a non-airtight drum, you can mix it all at once and store it. Alternatively, if storing such quantities is not feasible, you can use it in portions by mixing with water and store the remainder for later use.
